Hi All, I am new to the group. I have a number of B&O products which are all from new, however my CD player, Beo 9000 MK3, (the one with the six CDs) over the last year seems to be having a few issues with playing the CDs.
The CDs are originals, the unit picks up the CD but it does not spin then it states Pause. It makes a few noises like it is trying to do something but just freezes. I have never used the unit that much so it would seem it is more of a 'being left unused issue' rather than a mechanical one.
So do you guys know of a series of maintenance things that I should do. I have cleaned the two clear senors on the front, top and bottom. I have cleaned the two black senors at the top and bottom of the CD run. i have run a cloth behind the CD laser to try to remove any build up dust.
What else should I do?
Apprecial your help.
Alvin
