BEO 6 Wireless with Time Capsule
Anyone have this set up?
I can't get it to work .. . .
is there anything special?
mjmedlo,
Without a Beosound/Beomester 5 it wouldn't work. The Beomaster5 is the only device where the beo6 will work on.
Also the Time capsule is not a DNLA device. So it won't work as a hard drive (NAS) for the BeoMAster 5
I have the bm5/bs5
I'm trying to use the beo6 for 2way
I can't get it to 'find' the bs5
Check server ip in Beo6 wireless menu. It must the ip of your BS5 not airport/router.
If the configuration of your Beo6 was made with an older CT (4.11?) delete Beosound 5 and replace it with the version in CT 5.12.
I have no TC but My Beo6 World fine 2way with my airport extreme. So, if your BS5 does work 1way in your system the TC should be not the problem...
Hope this helps
Stefan
Yessir.
Got it figured out.
It's working like a charm now!!!
