Beo 5 Countdown- who get the first one...?
My dealer is asking £370 but down the road they are asking £395
There is no set price, they can charge what they like.
I got an email from my dealer, and he said it was £300 for the handset & charger, dunno if this was a special cause I recently bought a BV7, even so I thought it was pretty good. So I may have to go and take it for a test drive soon 🙂
JoC
At the time of set up. You can choose from logos for TV channels and radio stations from a very large library. You also get the option of using free text and choosing the colours there as well. Each button can be assigned either a logo or text as well as the IR code or sub-menu code.
This does require the software so make a list of what you want before going to get it set up.
The logo's are in the software that config the Beo-5. There are hunderd and hunderd of them for radio and TV, so your TV station will be there...
If not... say this to your dealer and B&O struer will add this to the sw. A dealer can download the newest sw for the Beo-5..
I hope that this is the answer for your question! 😂😂
I think that should be 455 kHz, and 20 to 80 kHz. Most other remotes are 36 (RC-5,6), 38 (most others), 40 (Sony), or 56 (RCA) kHz.
