Thanks I will give that a try.Then its most likely NOT the display but the conductive "rubber. Sometimes cleaning the rubber with Isopropylic alcohol can fix it, or simply removing the display an putting it back in. In the year 2000 Ericsson almost lost its cellphone business to the unreliable "zebra strips",- you are not alone!
Beo 4 remote problem
