Beo 4 AV function on Beo 5
I have just got the beo 5 and can`t find the AV "button" there. On the beo 4 I use list - AV - cd to get music while wathing tv, how do I do this on the beo 5?
The AV button will be available unless your dealer has deleted it or hidden it, if they have just hidden it, you can un-hide it yourself by going into the SETUP menu. To see how to do that follow the instructions in the Beo5 FAQ HERE
By default, if the dealer uses the configuration tool normally, then the AV button will be available
Thanx! Fixed it now..
The AV button is a tricky one. There are certain buttons (usually identified by the ellipse [...] following the name) that have a unique and uncorruptable constitution. As soon as they are touched or looked at in any way, they cease to work. The problem is a known one and will likely be hased out in a coming software update. There are apparently characteristics to the command that are not included in the values that a programmer can affect.
That being (awkwardly) said, I have made my own life easy since my setup requires lots of AVing, and simply given myself pre-AVed commands for things. You can do this by making the AV command inherent in the IR string. It will look like this 00.000.RADIO.TV for AV TV, or 00.000.TV.CD, for AV CD depending on which master you're acting on. In my home, I have an MX with a BC9000 connected via datalink. To use the speakers attached to the MX, I would issue an audio command to a video product. This way my AV button is unneccessary.
I can't imagine that helping, but there it is all the same.
Further to TripEnglish's statement, please be aware that changing anything to a command ending with ".." such as "AV.." or "Channel.." other than adding a logo will give problems, either serialisation errors or a subsequent blank screen where there is a sub-menu.
So, as a general rule any command automatically provided by the tool which ends with ".." should be left alone except for adding a logo if you wish.
Creating a Cinema button which controls the light levels and other functions should not be a problem.
