SW version menu says: 05.02b for STB TABLE" ... where do you find this info?
Beo 4 and apple remote
This topic has been discussed at least once before.
Here is
Kjeld ... Indeed I found differences !!!
This is from the SW Version Menu on my BV740 MKIII
H8 SW: 03.30a
STAT DISP SW 01.10a
M2 STB TABLE 05.27b
PW STB TABLE 05.27b
DVE FEP SW 03.20a
PW SW 03.30a
PIM FEP SW 1.20a
Do you think this is the solution?
/M
Munin: I assume the STB TABLE version number is the version of the STB list. So looks like yours is newer than mine (assuming your higher number means newer). That doesn't tell us anything about the iPod Dock/iPod Remote STB entry though. Second difference is the location where the iPod Dock/iPod Remote entries are selectable. With my BV7 it's in the SET-TOP BOX menu, with yours it's in the OTHER menu.
So I guess questions that only B&O is able to answer.
The only thing I can add to complete the story is how I got my version of the STB list. My dealer came by to upgrade the STB list, but was unable to do so using the latest B&O service tool; apparently the BV7-40mkIII and BV8 use a newer version of the B&O service tool. So, what my dealer did is use the old B&O service tool and acted as if my BV7-40 was a beosystem 3.
Thanx Kleld for all valuable comments.
Let's hope B&O follows this forum.
Bugfree software on my wishlist!
/Munin
