beo 4
I recently had to reset the pin on my beocentre 2 after a power failure now my remote will not work I remember I had to programe the remote in when i got it but can't remember how I done it   can anyone help
Sounds like an option programming issue. With the product in Standby press LIST and STANDBY at the same time, then LIST until OPTION is displayed on Beo. Hit select/go. Now press LIST until you get A.OPT then press 1 while pointing the remote at the BeoCenter 2.
Should solve it. Sorry if not!
