Bemoaster 1200, 3000uf Capacitor Polarity
Hi
Almost finished the re-cap of my BM1200.  Only thing is I am totally unsure of the correct connection of the 2 3000uf caps.  One had clearly marked polarity, but the other was an old original Wicon.  I can not decipher its polarity marking.  I attached the multimeter to determine polarity but do not trust the outcome.  Rather than run the risk of blowing up my hard work, I am posting to see if some one can tell me which wires (yellow, green; orange, blue) go to positive and negative (obviously the new caps are clearly marked).  Here is the story so far-
Original BM1200 caps.  The right hand cap is clearly marked, so I copied that for the new cap.  The left cap is not clearly marked so I measured the DC across the connectors.  That suggested the right connector is +ve.  This is the initial information I followed when connecting the new caps...
1200 initial connection based on multimeter reading of DC across old Wicon cap (which I do not trust).  yellow-, green+; orange+, blue-.  This did not feel right, so I also measured the DC across the clearly marked old cap.  I got a -ve reading when red was connected to + and black to the black connection; strange. Danger, danger!!!  Time to reference my working BM1001...
My BM1001, which I just opened up for reference.  The polarity of these according to my multimeter (DC reading) is yellow+, green-; orange+, blue-  That would seem to be logical.  Is this correct?
Thanks for the advise!
Hi
I have same operation ahead. Do yuo happend to have list of caps neede?
Usually, the square (and triangular in double caps) marked pins are positives.
Doesn't it say "Plain Neg." on the old cap ?
The cap does read 'plain negative.' I looked that up on line and found a guy who had the same challenge as me on a different amp.  He concluded the flatter/simpler pin was +ve.  that contradicts my DC reading on my working BM1001.  What does 'plain negative' mean?
There is a slight difference between the pins in the BM1001 (Last image above).  The left looks like a slightly smaller diameter and has an impression in it.  The right is slightly flatter.
Hi Orava - I simply got my cap kit from Dillen (he has posted below.  You could PM him).  Comes with simple visual instruction.
I also referred to the user manual to help locate pins on the back of the PCBs and will use in a while to adjust the trimmers.
OK, sat down with the service manual this evening -
Using the PCB diagram (and looking at the actual PCB), I can see that the yellow wire goes to TR36 and the orange to TR38:
Then looking at the circuit diagram I could see that T38 goes to the Left Speaker cap +ve and T36 goes to the Right Speaker cap +ve.  So, orange and yellow will connect to the cap +ve pins.  Using the PCB diagram (above) and following from the speaker connections back to the caps confirms the blue and green wire connections:
So I will be switching my yellow and green wires around; which matches my readings off my working BM1001.
Eureka?
