tkl wrote:
Where can I find more info about the setup tool?
And which players are supported?
Are there any requirements for the players?
Kind regards,
Ton
The setup tool is web-based and located at link. When the necessary software is running on the Raspberry Pi, the setup tool can connect to it over the local network and get you through setting up the BeoCreate 4-Channel Amplifier. It works directly in the browser and doesn't need to be downloaded or installed.
From the start, the available sources are Bluetooth, Toslink, AirPlay 1 and Spotify Connect, so there's a wide variety of devices you can use it with. Note that there's no BeoLink (NL) integration – it's a standalone product at the moment. Of course, as the software for BeoCreate is open-source, everyone is welcome to dig in and experiment.
There's documentation of some of the software on HiFiBerry website: link
And of course I'm here to answer any questions you may have about it.
Tuomas
