Bang & Olufsen app iPad support now in beta
andy_js wrote:
The last update to the app seems to have broken a bunch of things.  I can no longer find my DLNA server (Twonky on a Mac Pro) which my Moment has no trouble with (never thought I'd say that!) and I am unable to play from Apple Music for more than a few minutes before the song gets cut off.  Either one of those issues on their own wouldn't be a big issue, but to have both really sucks.
Is this Version 1.2? (I haven't updated the B&O application, and won't, for the foreseeable future if upon every version update, there are issues which cripple usability)
@Seethroughyou: We do not support the BeoMusic app anymore. You should be able to change the volume just fine on the core? Please write me directly, then I can try to help you. Native control for the BNL90 is coming into the app soon
Sorry, I said Beomusic App when what I should have said is the Bang & Olufsen app. Yes, I have only an optical Toslink between the Core and BL90 - the volume now works just fine. You have also fixed the button to get you back out of the Playlist Queue. Having BL90 native control in this app would be the icing on the cake. You should also look at reducing the number of menus - there’s still a lot tapping in and out of menus and backwards and forwards - there’s still more magic to be achieved in this software. Try to see what other manufacturers apps are like. Keep up the hard work, it’s very much appreciated and lifts the hardware and physical products to full potential when the software works beautifully.
I’ve been beta testing the B&O app for a couple of weeks now and it’s certainly moving in the right direction. There are a few enhancements that I think would make a huge advantage and add to the overall user experience.
 Home Screen
I agree with Millemissen, the white looks unfinished (too much like Bose SoundTouch!) but the option to choose black or white would be good.
The product pictures on the homepage are great if your system consists of BeoLab 18’s, 50’s, a few BeoSound 2’s or you’re a dealer, but pretty un-attractive if like me, you have mostly BeoSound Cores!
To have the option of replacing the product pictures on the homepage with personalised ones from your photo album, such as a picture of your sitting room, kitchen, dungeon, family members or just a plain background.
The ability to see what is playing in each room from the homepage, and which rooms are linked together. A small overlay on each room tile with the current song along with a small image of the album art or radio station would be good along with a standby button for each room. When clicking on the relevant room tile on the homepage would take you to the ‘Now Playing’ screen for the that room
The ability group/link rooms by dragging the room you wish to link or join onto the master room on the homepage
I would also offer the option to remove the ‘pop up’ that appears when pressing the standby button that asks you if you’re that you want to put all of your products in standby, I find it annoying.
Now Playing Screen
This looks great, very stylish. A standby button for that room would be useful without having to open up the sub menu.
A Useful Addition
As a point of interest I’ve been using a couple of Yamaha WXC 50 MusicCast pre-amplifiers in the studio over the past few months, with some Beolab 4000 & 6000 speakers.
The MusicCast app also has an optional but unique function where you can allocate four customised pre-sets from a pop up sidebar, which can be different on each I-pad.
Holding your finger on the tab for 5 seconds can program each pre-set, and the tab can be renamed.
Whatever is currently playing such as a playlist or radio station, whichever rooms are linked and the current volume in each room is stored in the relevant pre-set.
I have one that is labelled ‘Morning Music ’ which plays from a Deezer playlist in the office at volume 20 and the studio at volume 40.
Although the MusicCast app lacks visual style, it does offer some great functionality, and some optional advanced features that allow the more experienced user to customise, it may be worth taking a look.
Keep up the good work,
Paul
I noticed that playing content from my NAS using the new app/Essence was almost gapless.
This is very important, if you listen to live/concept albums (and unfortunately not common to most DLNA renderers).
Anyone experienced the same?
Agree.
It serves the following song really quick.
I’ve also noticed the -almost- gapless playback, nice improvement compared to every previous B&O DLNA players!
I’ve got a very annoying bug which is still on the release candidate (just released) : I cannot navigate in a song using the timebar in DLNA : anytime I navigate in a section of the timebar, the music is stopped and I can only put the product to standby and restart to be able to lay music again.
Are you sure it happens for DLNA tracks? I have the issue with Deezer tracks on the Moment (reported to B&O) but not with DLNA.
What happens is that the music stops for the duration of the jump and resumes after, try moving 30 seconds forward and you should have a 30 sec gap without music befor it resumes.
Hej Rudy
Working on a fix. It should be on testflight this week.
Br
Thomas
