Bang & Olufsen App 3.00 prod/beta
mbolo01 wrote:
I confirm and I have added the issue to the list.
Hi mbolo01,
Yesterday I’ve reported the following problem via the beta feedback option in TestFlight:
During DLNA playback in the app to my BV Eclipse the “shuffle” and “repeat” buttons are not working.
I don’t think that it’s the same product problem that was fixed some time ago, because playback stops when the play queue is empty.
I will inform you when / if I receive any feedback from B&O.
Best regards
Dyssegaard
Thanks. I have tested the scenario against my Core and my BS 1 and both random and loop are working.
I’ll add the issue to another thread I started for version 3.1.
Hi
Can confirm this bug with lack of virtual keyboard for the  Beoplay V1 and Beovision 11 when a menu where text input is required is encountered, e.g. channel name and WIFI password
This is crucial for my Beoplay V1 as the infrared receiver is dead (Also known bug on this TV).
Hi
mbolo01 wrote:
Beobuddy wrote:
No, I didn’t. Be my quest.
Done. B&O Answer: will be part of 3.2 release.
Update: (for the iPad version)
-They've added an extra context menu when you tap the original standby icon in the product list. You will be asked whether you want to set the complete setup in standby or just the product you've selected. So there's not an extra standby icon, but an added context menu.
Correct, I already updated this issue status in a more recent thread about B&O App 3.2 version
Not sure this is the he latest thread on the b&o app?
There is something that truly confuses me and hope is just a mistake on my end?
Is there any menu where i can see what device is playing what? I’m streaming two different streams to two devices and then extend them to others. It works, but then turns into guessing when i’d like to stop the stream as i don’t remember what was the lead speaker of the second stream.
Also, i don’t think i can pause the stream of the lead speaker without stopping the stream for the rest?
you can see it on the home menu. if you tab a device, the joined devices in one group are all greyed. tab a white device with the joined icon than the other group is greyed.
It works but I prefer the way Beoliving is showing the difference groups though.
Another inprovement would be: Standby for a Linked Group
You cannot. With the App, pausing the lead pauses the group.
But from the physical device itself, or from a remote paired to the lead speaker, pausing the lead with a tap does not stop the other member(s) of the group.
Interesting test for Halo users as for me the Halo is closer to the app than other remotes.
I am not at home so can’t verify exactly which menus, but from memory after selecting a device you can bring up the control screen with the volume circle. On the right hand side there is either a join icon (or is it the 3 dots?)
There you can see the multiroom group and add or remove devices, and also change each volume individually.
Tim
