Bang & Olufsen app 2.7
I apologize for not visiting the thread lately. I have been travelling. The remote bug is fixed and will be out shortly and I have bumped the beta version to be on par with the live version. It will be out when the review is done.
The minor versions only fixed issues for the upcoming product launches.
Hi
A cafe I frequent has a beolab 35 high up on the wall, and the owner told me he has to climb up and manually alter the volume each day, which is unsafe and ticks him off.
He has the app on his iPhone but says it doesn’t “work”.......
Dumb question maybe, but can he control the 35 directly using his app on his phone via Bluetooth , or must the 35 be on a wifi network first?
He appears to be able to stream music to it.
Can you control a 35 using a Beo 4 remote?
Hi.
I have a problem with sync of music when using multi room.
The problem is as follow:
If I start a song/radiochannel in living room using Moment/Avant combo it works fine. When I add another room (sync/partymode) it works like it should in the newly added room, but the music starts to come and go in the main area  (living room).
Somebody else have experience this? It wasn't like this before...
Both devices need to be on same WiFi network.
Yes you can.
Great. How would I add a 35 to a standard  Beo 4 remote so it could control it please?
Do I need to set it up as say "camera" or something else?
This may help:
mbolo01 wrote:
@Synth
Follow the instructions so kindly provided by mbolo01 and it will work.
HH1971 wrote:
Dear MrAndersen I strongly wish / support following five feature requests for the B&O app already mentioned in this thread.
  1. Deezer Flow - one of the best features of the Deezer app.
    Alsfeld wrote:
    1. A Deezer Flow button to start / to stop Deezer Flow somewhere in the B&O App.
  2. Possibility to reduce local source list in the now playing screen.
    Alsfeld wrote:
    Even I disabled several local sources of my Beosound Core (see left screenshot), they are still displayed in the source list (see right screenshot) in the now playing screen.
    Millemissen wrote:
    Agree - there is some work there to be done in order to make these entries corresponding.
  3. Genre overview - with much smaller pictures per Genre, so that you see more content without scrolling
    mm08642 wrote:
    I would love / suggest to follow the Deezer design (as you did with Artists using round circles instead of squares). Deezer is using small rectangle instead of squares for displaying genre.
  4. Clearer multiroom screen, you see all groupings at once, without changing selected products
    MrAndersen wrote:
    Redesign of multiroom screen
  5. A fully working app (not freezing) within a local network when DSL connection is not available (= no internet access, only local network access)
    HH1971 wrote:
    the bug that courses a freezing app (after 3 to 6 minutes when there is WLAN / LAN connection to B&O products but no Internet connection) is not solved!
Please implement these features, that would be really great!
MrAndersen I support these 5 suggestions from HH1971, too.
That the B&O app gets a little bit closer to the functionalities of the Deezer App, at least. Even so, the Sonos App should be the benchmark.
Hello,
The drawing depicting the device, in my case a BeoPlay V1, disappears then sometime it is flashing on the black board for a fraction of a second.
Cheers.
Olivier
