Bang & Olufsen app 2.7
Dear Mr. Anderson,
I am reporting a bug for the latest 2.9.0 beta.
In the Eclipse remote control menus, when we swipe forward and then backwards, the text is now surimposed as shown in the example.
Thanks in advance,
Jean
Same for the BeoPlay V1.
jvezina wrote:
Dear Mr. Anderson,
Thanks in advance,
Jean
And for the Avant 4k MK 1.
I sent feedback via TestFlight within hours of release and have subsequently downgraded to the previous build 23122
And the Avant 4k MK1
I sent a bug report just after the beta was released, and have subsequently downgraded to build 23122
Tim
Maybe time to open a 2.9.x thread knowing that latest beta (2.9.0.23217) is already behind production (2.9.1.23573)
We are back to bad habits where beta users are no longer informed properly and may be reporting bugs already corrected in commercial versions.
Hiort wrote:
@Mr Andersson. A problem to look at.
Setup:
Beovision 11-46 with a Beosound 1 GVA integrated. BL3s connected to the BV.
What I do:
Start playing a Deezer playlist from the app.
Use app to join the BV11 to the experience.
Silence sound on BS1 using the app (dragging multi room slider to zero)
Adjusting volume on BV11 from the now playing screen on app (the circle)
What happens:
Volume on the BV jumps up significantly, and also the BS volume jumps up.
If I use the BeoremoteOne the volume works okay.
I’m able to reproduce this.
I’ve had the same thing happen, only with TuneIn, Beoplay V1, and an M5.
We are back to bad habits where beta users are no longer informed properly and may be reporting bugs already corrected in commercial versions. BS Moment, BS Core, BS Ouverture, BG 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
I totally agree.
@MrAndersen: Is the beta program still alive?
Best regards
Dyssegaard
Seriously?
The same bug I and others reported is still present!
The text in the bottom row becomes superimposed when swiping right and left.
This makes the App unusable with a TV.
I will downgrade to an earlier build again.
Hey,
Probably a dumb question but I cannot figure it out. How do I downgrade to a previous app release? Do I need to be in beta program?
I agree with you, totally unusable with TV at the moment.
Thanks,
Koert
Yes you need to be in the beta program so you can load previous versions case needed.
