Bang & Olufsen app 2.7
Today reset M3 to factory settings, now I can change name in the B&O App (so without Apple Home App), and also in de BeoTool App can change the name of the M3.
I can't make sense of it to be...
But problem solved🙂
Even I disabled several local sources of my Beosound Core (see left screenshot), they are still displayed in the source list (see right screenshot) in the now playing screen.
Why? That does not make any sense!
I would like to have a short list without the necessity to scroll (on the iPhone) for STANDBY, without all options I disabled and I do not use like SPOTIFY-APP ÖFFNEN.
Another suggestion (on top of the one I raised previously):
To display the track artist instead of the album artist in the play queue items, more informative for compilations and consistent with the now playing screen:
Agree - there is some work there to be done in order to make these entries corresponding.
If ordering of (and excluding some) entries in the settings is offered, this should also show up in the list.
Was probably somewhat forgotten 😉
Today I’ve noticed that the app shows a notification when a sw-update is avaiable for your products:
In this case there was a sw-update for M5 (and also for Core).
I have installed both updates but havn’t spotted any changes yet.
Best regards
Dyssegaard
Interesting, what versions do you have now?
mbolo01 wrote:
Interesting, what versions do you have now? BS Moment, BS Core, BS Ouverture, BG 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
M5: 1.21.34088
Core: 1.6.34089
Best regards
Dyssegaard
Dyssegaard wrote:
M5: 1.21.34088
Core: 1.6.34089
Merci
@Mr Andersson
Feature request:
A more handy place for battery status for the Beosound 1 would be nice.
Currently you have to go into the web interface part to see that information.
New issue in 2.8.xxx, beta and commercial:
Moving forward/backward in a DLNA track does not work properly.
Tested and reproducible on 3 different DLNA servers (Twonky, Minimserver and PLEX)
If you move forward to 00:30 by pressing on the progress bar, playing point resumes around 01:15
If you move forward to 01:00 by pressing on the progress bar, playing point resumes around 2:30
Same test with a Deezer track has no issue.
I remember this bug in the early versions of Moment software.
Over to you Mr Andersen
