After some investigation I'm suspecting it relates to the products as well. It wasn't doable before our 2.4 deadline, but I will move it into 2.5
Perfect, thanks
Perfect, thanks
Another "interesting" B&O multiroom behavior:
Core is my main product
BS 1 + A6 + M5 + M3 have joined the Core in a B&O multiroom group
I start playing a DLNA album which adds the album's tracks in the now playing list
If I empty the now playing list (Trash Icon), Core stops playing as BS 1 and M3 do .... but A6 and M5 continue playing ..... something wrong here isn't it ?
@MrAndersen:Hi Thomas. On my BV11/Core integrated setup the loop and mix icons are not present when I play DLNA music. Please see attached screen shot: Login to view imageWhen I do the same on my M5 the loop and mix icons are present: Login to view imageHopefully you will be able to fix this also when you fix the loop issue 😕@Dyssegaard: When the play queue loops the loop icon is disabled? Br Thomas
Hi all
We have now verified that this is a product issue. I have transferred the bug to them and will get back with an ETA on a fix.
When we test it, it always repeats. We cannot turn it off.
Hi all
Thanks for the update, can't wait for product update then, ALL products .... as they all behave the same.
My Beoplay M5 was updated to version 1.20.30101.247491601 tonight, and now the loop icon works.When the loop icon is bold no looping occurs (see first screen shot) and when the loop icon is selected and no longer is bold, the music will loop (see second screen shot). Login to view image Login to view imageI have verified this with a simple play queue with only one song from my Plex DLNA server, but I will do some more testing in the next few days (also on the shuffle function).Hi allWe have now verified that this is a product issue. I have transferred the bug to them and will get back with an ETA on a fix. When we test it, it always repeats. We cannot turn it off.
I updated mine and it seems that the looping function is consistent on the M5, I'll do more tests too
Note: when the icon is bold it means that the function is engaged.
Unfortunately this M5 update does not solve the unsolicited looping issue, which is consistent with Mr Andersen message where he just reported it to the product developers.
I have done some more testing, and you are absolutely right - the play queue still loops no matter the setting of the loop icon.I have testet with different lengths of the play queue, and now I cannot reproduce my results from last night with only one song in the queue - now it always loops 🙁Unfortunately this M5 update does not solve the unsolicited looping issue, which is consistent with Mr Andersen message where he just reported it to the product developers. BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
