@Kuyttendaele: That was bad, found it and fixed. Updating today, will be available for you after apple review
It's working! Thanks for the very quick fix :-)
Karel.
Karel.
Are you going to add the possibility to change the BV Eclipse cover colour like in the BS 1 and 2 product settings menu?
I have the same problem 🙁@MrAndersen With today’s update the link to the product configuration pages seems broken. When I click “configureren” the app tries to go to the Product setup pages, but doesn’t succeed, and returns to the app’s main page
+1Fortunately you can still use your browser to fill the gap.@MrAndersen With today’s update the link to the product configuration pages seems broken. When I click “configureren” the app tries to go to the Product setup pages, but doesn’t succeed, and returns to the app’s main page
Hi MrAndersen,
I am having a new problem where my devices appear in the app, but as soon as I go to play something I get a series of error messages. First - "added to play queue", then - "could not insert into play queue", then finally - "besound 2 is not reachable"
I have been having these issues with the last few versions of the app. Sometimes powering the device on/off will resolve it, other times it won't. Sometimes uninstalling/re-installing the app will resolve it, other times it won't. I do not believe it is a network issue, as most of my products (see list below, plus a recent addition of a beosound2) are hard-wired. It happens to both wired and wifi products. When this happens, I usually resort to chrome-casting my music which always works (another reason I do not believe this is a network issue).
I have the latest firmware and am on the beta program for the app.
Has anyone else experienced this problem?
Dion.
@Jans: The configuration page issue has been fixed, timing issue that for some reason appeared more frequently on non-english phones
@Dion: That sounds like either a product problem or a network problem. That is hard for me to investigate and I must ask you to contact support. Is specific for that product or is it happening to all products?
Hi MrAnderson,
It is a problem on all the "speakers", that is, there is no problem on the Avant or the BeoSystem4. I don't think this it's a network issue (for the reasons in my original post), to me it seems to be an issue between the app and the products. Should I still pursue this through product support?
@MrAndersen
Same for me now on version 18302 (from 06.01.2019) - just tested.
I had exactly this problem with my BS2. I didn’t think it was a network issue, but it was. Sorted it by hard wiring, now no problems at all.Hi MrAndersen, I am having a new problem where my devices appear in the app, but as soon as I go to play something I get a series of error messages. First - "added to play queue", then - "could not insert into play queue", then finally - "besound 2 is not reachable" I have been having these issues with the last few versions of the app. Sometimes powering the device on/off will resolve it, other times it won't. Sometimes uninstalling/re-installing the app will resolve it, other times it won't. I do not believe it is a network issue, as most of my products (see list below, plus a recent addition of a beosound2) are hard-wired. It happens to both wired and wifi products. When this happens, I usually resort to chrome-casting my music which always works (another reason I do not believe this is a network issue). I have the latest firmware and am on the beta program for the app. Has anyone else experienced this problem? Dion.
