Bang & Olufsen app 2.3 beta released
Nidi wrote:
Yes, that i mean...sleep timer function...
I would love to have the sleep timer function.
Especially on the televisions.
At first the new release couldn't access my BeoPlay A1 and S3.
After removing the A1 and S3 from the bluetooth devices on my iPhone 6 the app could add and access the A1 again. Still can't add the S3. It does find the S3 but when adding it I get the error "An error occured, trying to add the product to your account".
Functionality of BV14-40 remains excellent.
Karel.
The report function to b&o care in the app does not work. Not able to send a message in the selection page of the regarding product.
Slightly off topic, Since a while I do not get any response on reported errors any more. Is the b@o care team still in place?
Serge
App works well with my P2.
Think it would be nice to get some kind of visual indication that the app have detected e.g stop / start / next track .
You of course hear what is happening, but that would give a better feel.
3 out of 7 products do not work.
It does not really like my BLGW. The app works but my BLGW refuses. I am already done for now, no patience.
@Nidi: I see, I will investigate
@Millemissen: I finally found an internal guys with the same problem as you got. Will work with him to resolve the personalization that disappears
@Kuyttendaele: If you have never updated the S3 then it is not compatible with the app. You need to update it using a cable first. Could this be the case?
@Fansastic: Our support is currently being restructured. We have an external company handling 1 tier, the more complicated cases will go to Beocare
@Hjort: Good point. I will ask the designers
@chucky: The first view is from the Beolink app? What is the problem with your gateway?
It has not been updated for >1 year... that could indeed be the case! I'll update it over the weekend.
Thanks!
Karel.
Oh well, that makes me feel a bit calmer.
By the way - logging out and in again did not change anything here.
First time I can change sound level of my BS3000 via NL/ML converter!
Very nice, is this a new function being tested? Hopefully the icon and picture will be changeable to BS3000 (or other system connected to the BLC)
Another issue for the Android-app: the TV-remote suffers from clipping on smaller screens. So you can only turn volume and programma UP but not DOWN. Not really convenient :-)
