Bang & Olufsen app 2.3 beta released
How can I get access to test the beta app? I have TestFlight installed on iPhone.
I have just updated the post with a link. You can it through that
MrAndersen wrote:
@Dyssegaard: That is the latest version of the A1?
Yes, it is on the latest version, but it would be good to have the app state if this is the case or an update is available ...
Best regards
Dyssegaard
Ahh, well we have actually added that. You will see a red dot on the gear in the home view in case there is an update. The dot will then also be on the product in the product list
@MrAndersen .... a timer option directly to the product page would be nice for my Beosound 1 in the bedroom
The alarm control is here, or do you mean on the home view?
@MrAndersen: I think Nidi means the sleep timer function (that is available on the ip-settings page)
Yes, that i mean...sleep timer function...
