Bang & Olufsen App 2.0 is open for beta testing
Looks good to me.
Headphones 100% as shown by the small vertical black bar. iPhone at 57% as shown by the text and horizontal bar.
ngnear wrote:
Looks good to me.
Oh dear
How embarrassing!
Is there any way to rearrange the list of radio favourites? If not this is a feature request!
You reorder them from Tunein webpage.
.....go to Favorites, open your Favorite Folder and simply rearrange.
This is the order, that you will see in the Bang & Olufsen app afterwards - and this is then stored in the devices.
Thanks for that. I actually used the TuneIn App to rearrange the favourites list. The B&O App updated almost instantly.
Problem solved!
It will be nice if it's possible to play Deezer/DLNA music directly from the B&O App on the headphones😐.
You can find the answer (from Mr Andersen) to that wish on the previous page.
Thanks, shame on me.
Disappointing it's not possible.... How smooth is it, to control everything by one app. Even outdoor on the 4G network (headphones only off-course).
The notes of the just released beta version says:
’Settings only products moved out of home’.
Thanks for that ;-))
You can still access these in Settings (the little gear symbol above the products in Home View) and then under Products.
