Bang & Olufsen App 1.9.9 beta
Thanks everyone, I will check PLEX and I guess I set up a server.
Bests, Stefan
Hi Thomas.
I have tested version 1.9.10.14858:
- Color picker is now gone for all my products (previously it was only my integrated BV11/Core setup that had problems) 🙁
- The TV icon flicker in the "Now playing" window is gone. The TV icon is steady. However, there is no longer any info about the selected TV station 😕
- There is still update problems for the DLNA covert art in the "Now playing" window. For the first selected song the cover art is displayed, but when I step through the songs, the cover art disappears. If I close and re-open the now playning window, the cover art is displayed again 😕
Furthermore I have discovered the following issues. They may have been present in previous versions also:
- When a TV source is playing on the BV11, the Core (integrated with the BV11) is in the list of selectable products in the "Multiroom" window (BeoVison 11-40 Group) together with my M5. Being integrated with BV11 it doesn´t make sense to add the core to the group as it points back to the BV11 speakers already playing.
- When a source from the Core is playing on the BV11, the M5 is not shown as a selectable product in the "Multiroom" window.
- In the TV-remote, the "Line-In" from the Core is shown as a selectable source, although it is not in the TV-source list. Other sources are in synch with the TV-list.
- When I log out of the app and back in again, the placements of my products are reset on the home screen.
Dyssegaard
On my app there are no back button at all (version 1.9.10)
In order to see the back button you must launch the Multiroom from a now playing screen. I have 1.9.10 too.
🙂In order to see the back button you must launch the Multiroom from a now playing screen. I have 1.9.10 too. BS Moment, BS Core, BL 18, BL 19, A6, M5, A1, H5
....and you must look twice - white text on a light grey background is not the best.
Can you change the colour of the Eclipse? I’ve changed it for the BeoSound 1 and 2 but that option is not available for the TV
