B&O Radio Migration Available now
Just to complete the information about B&O Radio and the BeoSound Moment, may be some will find it useful.
Customer Service informed me that the Moment is not and will not be upgradable to B&O Radio.
Although TuneIn will be swept from all other devices, it will remain for the Moment to be used with. So, in a way, I think it can be a positive aspect, if using a Moment in the network, it is possible to access both B&O Radio and TuneIn, still.
Kind regards,
Rolf
Hi Rolf,
I am now able to switch radio stations using Beo4 straight on. No need to use the app first anymore! I have not noticed a software update, but I did fiddle a bit with the Core settings though. The only thing is that I cannot choose the first station in the B&O radio list by pressing a '1' nor pressing '01' nor pressing '1 GO'. The other stations do respond directly. I have asked B&O for this.
Keep you posted, Johan.
Hi Johan,
that is great, good news. Reading your post, I went straight trying it with my Beo 4, but was not successful, still. No numbers nor up-and-down buttons release a switch.
I will check my Essence settings at the weekend, if there may be time. Might be a difference to the core. I keep my fingers crossed. And thank you for the information!
Rolf
I am using 2xCores, A9, Stage and BeoSound 1 with TuneIn, but mostly AirPlay.  I did the migration since my TuneIn stations are mainly those that I can't get easily in the US. So I have around 20 favorites and most of my stations ported over. A few that did not, I got recommendations and that worked fine for me. I use Beoremote Halo and Eclipse Remotes, along with the App for music and it works fine for me.
I suppose it depends on the devices one has. I do wish one could arrange the order of the stations. Looks like it is LIFO - last added get to the top of the list.
Agree with Jaffrey.
The option for reordering the station list should have a high priority for B&O IMO.
Some people prefer the old TuneIN option because of the fiddling with reordering their favourites in B&O Radio.
B&O’s intention for launching B&O Radio was to make things better!
Just received the notification for the new beta version of the app.
Seems that the reordering issue is fixed  = probably soon in the regular app version too.
Play B&O Radio on the headphones……sounds very interesting.
However, I will have to wait to test untill tomorrow….it is late.
Reordering works as expected, but it’s not very ergonomic : I thought a long press would allow to reorder station (like on your iPhone home screen), but you have to click to the radio menu, and then modify to access to reordering.
Listening to B&O radio on a (B&O) headphone just works, nothing to complain about.
@Mbee
I had/have no issue with the way one reorders stations.
It is the same logic as when you reorder your products on your main screen in the app.
Listening to B&O Radio on headphones however, is still pretty beta - I think.
In my case my danish stations works well - the Radio Paradise stations are added to the queue, but do not start.
From the BBC stations (1-6), that I have in my list only BBC6 starts.
The Linn Radio stations work fine.
So still a bit of work to do - I did report back from within the app.
