Posted December 4, 2022 at 14:06 GMT
So, after returning to my home, I tried the migration I did trigger during the week in the app, et voilá, it proved to be working - almost.
All devices are working, except my BS Moment. It shows B&O radio surface as well as TuneIn, but is still fixed on TuneIn. Even if I set it in radio services on B&O Radio (which I had to do by ticking the circled box manually), it plays TuneIn. A manual switch to B&O radio brings up the "not supported" message.
In the menu of the connected BLC I also am able to only select TuneIn. it does not show B&O radio as my other BLC does.
Anyone here who has done the migration with the Moment?
Strangely, the afore mentioned second BLC, connected to my BS Essence MK II, says in the app menu, that it is integrated with the Moment, which it definitely is not.
@Johan:
After having set all devices to B&O Radio, it seems that I am able to switch radio stations with Beo4 and BR1 in IR mode, if I start the Essence with my remotes. Still, I am not sure yet, if I did something with the app before using the remotes, so I will keep testing.
Rolf
