I am trying to connect the Beosound Theatre to the Beolab 18 with cables.
Got from B&O some powerlink cables and after discusion with the local service agent we agreed to connect it from one side straight to the Theatre and cut the other end of the cable to connect it to a wall socket from ABB (the powerlink cable which I run through a wall tube). From there run another b&o 3 meter beolink cable to the speakers.
The problem is that no matter how well I do the connections in the wall socket, I always here noise from the Beolab 18
Any thoughts or tips?
Thank you
