B&O Playmaker?
jonasrosen wrote:
Just an observation, according to the spec on the Bang Olufsen page for the Playmaker, it does not support WMA lossless... Which makes me wonder how useful it would be for BS5/BM5 where it is recommended to ripp into WMA lossless (which I have done)???
Why would you use the Playmaker if you have a BS5?
Playmaker in a separate room connected ro speakers accessing my music collection (BM5) which is in another room.
That will work, because bm5 is d lna server.  You would use an app on your phone to play music from bm5 on the playmaker.
If you want to sync both rooms (same music at same time) you would need ml between them.  Personally, having made the investment in a bm5 I would run the ml and get a beo 6.  Playmaker is aimed more at people looking for a cheap way into band o, and wouldn't give you the best return on the investment you have already made in the bm 5
I already use ML, but would prefer having it independent of what is playing in the main room
Then a playmaker will work.
A bs5 encore would be a lot more elegant and user friendly though
I goes this is how it looks!
Regards,
Bieele
Not really, since in the specs it says it does not support WMA lossless!
(So I have to stick with using my dlna app on my HTC, which controls the main room BS5/BM5 which I then access in link room using link a aux.)
PAUL W (STEVE JOBBS LOVECHILD)
WHY DONT YOU STICK TO THE APPLE FORUMS,i AM FED UP HEARING ABOUT "SEXY DESIGN THIS AND THAT" RADIO STATION THIS..i HAVE READ ALOT OF YOUR POSTS ETC AND IT CLEARLY SHOWS YOUR HEART IS WITH APPLE.YOU KEEP SAYING I WILL BUY THIS AND THAT,BUT NEVER DO.
i TOO HAVE MANY APPLE PRODUCTS,BUT USE THEM AS TOOLS FOR WORK.I HAVE BEEN BUYING B&O SINCE i LEFT SCHOOL AND WORKED HARD AND SAVED UP FOR WHAT I REALLY WANTED,AS FOR ITUNES,ITS FINE FOR HEADPHONES BUT POOR SOUND QUALITY,YOU HAVE TO RIP YOUR "OLD FASHIONED CDS" TO LOSSLESS TO GET A DECENT SOUND,.
MOST PEOPLE ON HERE BUY B&O ON A REGULAR BASIS,NOT A CENTURY,BV6,DVD 1, YEARS AGO,MOAN ABOUT THEM,THEN NEVER GET ANYTHING SINCE.I GOT IN TO B&O THROUGH FAMILY, AND MOST OFF MY FRIENDS HAVE ,BEEN BROUGHT UP WITH IT.
I BUY B&O FOR THE QUALITY,PERFORMANCE,EASE OF USE,AND DESIGN, B&O PLAY IS A GOOD IDEA,BUT DOESNT HAVE KUDOS OF THE BANG&OLUFSEN RANGE.lIKE D&G AND DOLCE&GABBANA,DIFFERENT MARKET.
i AM MAYBE DIFFERENT BUT I WOULD RATHER HAVE A USED BENTLEY THAN A NEW VW,AND A USED BEOVISION THAN A NEW BEOPLAY.YOU AND YOUR HIP CROWD SHOULD PUT YOUR MONEY WERE YOUR MOUTH IS,AND START BUYING INTO THE APPLE FOCUSED BEOPLAY RANGE,WHICH IT IS CLEARLY TARGETED AT.SO GO AND PLAY ON YOUR CENTURY TAPE PLAYER WANNABE
AGREE ASWELL
butch1 wrote:
PAUL W REPLY TO STEFFEN.
i AM MAYBE DIFFERENT BUT I WOULD RATHER HAVE A USED BENTLEY THAN A NEW VW,AND A USED BEOVISION THAN A NEW BEOPLAY.YOU AND YOUR HIP CROWD SHOULD PUT YOUR MONEY WERE YOUR MOUTH IS,AND START BUYING INTO THE APPLE FOCUSED BEOPLAY RANGE,WHICH IT IS CLEARLY TARGETED AT.SO GO AND PLAY ON YOUR CENTURY TAPE PLAYER WANNABE.
