Dear Curmudgeon,
By the time the first TV arrives with your dealer, I should have the first batch of Powerlink converter cables to allow you to play sound from the V1 out to the Aux input of the BeoMaster 7000.
If you want to drop me a line when you have had a chance to look at the TV, I will be able to confirm exactly which cable you need to add a V1 into your setup.
Kind regards, Steve.
