B&O Core crashes
did anybody try to use a fixed IP address for the BS Core?
without fixed IP address: what happens if the router's lease time for an IP address is extended to for example 1 week
if WiFi-connected: try to push the Core to the 2.4GHz and to a fixed channel (f.e. 11)
I find it very odd that this problem still happens on ethernet as this sounds like it's interference over wifi?
Here's an update on my Beosound Core repeatedly crashing. After several months of discussion with my local B&O dealer who, in turn, was in discussion with B&O product Support, I believe the problem has been fixed. According to the dealer, a new software version for the Beosound Core was released by Bang & Olufsen at the end of October. According to the release information, this update specifically addressed several connectivity and stability issues. Based on the fact that my Core has now been running perfectly for the past couple of months (as opposed to crashing once or twice every week or two), it seems that the Core software was the problem.
Sighs of relief... 😃
I have the same issue, over wifi. I've not tried ethernet yet but doubt that's the issue. The device basically just hangs and requires a reboot. Latest version doesn't help either. Version 6.5.57688
Sounds identical to my issue. But do you mean that you have a newer version from the one I wrote and it works now?
