B&O Beogram RX2
So after switching left and right channels onto the mute switch I now conclude there is a short in the left channel wiring between cartridge and  mute switch. Seems terminal as in no hope. I have bought another arm plus pivot on e bay and will try to re fit it.
Mike
Check under the black carriage cover.
Do you mean at the back of the tone arm where the wire drops down through the arm pivot?
Mike
Top cover of the sliding carriage, covering the arms fastening points etc.
Two small black screws and one silver.
Lift it off carefully as the leads can sometimes bind to the underside of the cover.
Hi Martin.
I changed the arm and refitted everything. All is now working. Sounds fantastic such depth in the stereo image.On another. subject. I got a Beogram 1800 with a working MMC5 cartridge..
Wires were broken by the arm entrance at the back of the arm. I tried to resolder some thin cartridge cable but to no avail. The two leads in question are the ground lead from the arm and the ground lead on one channel.
If I combine the two cartridge ground leads at the cartridge. and re separate the two ground inputs on the input to the small pcb board that connects to the phono leads will i get a stereo image?
Or shall I try to get a replacement arm?
Thanks for your inputs.
BTW what does that small PCB do?
Best Regards
Mike
Hi Saint,
I want to do the same thing, but I have a recently repaired and tuned with new soundsmith MMC cartridge Beogram 5000 connected to the Beomaster 5000.  (I also looked into the AT, but am hoping I can find a purer way to do this.  I want my digital recording to be as hi fidelity as possible, even picking up the pops and scratches that might be on my records.)
I could:
1. Get a pre-amp connected to RCA cables from the Beogram and an analog to digital converter as you suggest.
2. Connect the Beogram to the Beomaster with the 7-pin DIN and then use RCA cables to the Pre Amp out from the Beomaster and connect  an analog to digital converter.  The Beomaster would be the pre-amp.  I might even be able to program a mix of record, cd, and tape to be output to a single file . . .
I think #2 would get the purest Beo-sound, but might introduce issues or not be as good as #1.
What do you think?
(I hope to take the digital files with me to listen on the road, but I know the sound will not be the same.  Worth a try.)
AKML wrote:
Hi Saint,
I could:
What do you think?
Sure #2 would work without having to buy as much gear and cables as #1 considering you have a functional BM5000. But as you said, more issues with volume control, etc. I don’t know what a pure “beo-sound” sounds like but the idea in hi-fi is not altering it modifying in playback how music was presented when recorded. I love the BM 5000 but in this situation I can get cleaner reproduction with a great phono preamp and less circuitry in the path from my Beogram to the computer.
All this to say, in my opinion, nothing is pure about digitizing vinyl and then playing it back on the road.
