B&O App - Ver. 3.x.x Issues tracker (beta & prod)
New issue to the list:
  • No more possible to play local iTunes/Music AIFF files since IOS upgrade to IOS 14.1 (case 270564 raised by Antonius Robin Iriawan in October 2020, case 273969 raised by mbolo01 in October 2020 )
No more possible to play local iTunes/Music AIFF files since IOS upgrade to IOS 14.1 (case 270564 raised by Antonius Robin Iriawan in October 2020, case 273969 raised by mbolo01 in October 2020 ) BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
not only AIFF but also WAV
Tracker updated, did you open a case with B&O by any chance? The more we are, the more they should focus on it.
Dear mbolo01,
I received a reply for my case 270564
It says
"Dear Antonius,
Thank you for your patience so far.
We just heard back from our technical team and were informed, that there might be a compatibility issue with the file format and your iPhone, as this device is the only thing that actually changed in the setup since it stopped working. Can the iPhone currently play AIFF files on its internal speakers?
We are looking forward to hearing from you again."
I replied them my phone plays AIFF file well and sounds good
Prod version has been updated. Interesting support of « Beogram 4000 », not found when adding products and new support for coming « BV Contour » configurable through the Soundbar (Stage ?)
Beta is stil on 3.7.2, official 3.7.5
This happens frequently.
Long time ago MrAndersen had been diligent on keeping both aligned as much as possible after we first complained, but this was before ...
I’m regularly checking if prod is ahead from beta and i frequently use the production one, hoping that old bugs have not been introduced back, check if no new bugs have been introduced and finally check if by any chance the one I reported months ago have been fixed ... I never win on the three fronts 😁
And now no more Contour ....
New beta out
- Widgets « old style » are now configurable
- new TouchtoJoin widget (works well)
Still no icons for some products and minimized screen view still overlaps second icons’ raw
mbolo01 wrote:
DLNA playback issue on BeoVision Eclipse - Shuffle and Repeat buttons have no effect at all ( case 209996 raised on July 1st 2020 by Dyssegaard)
This was fixed today by a sw update to the Eclipse 🙂
Best regards
Dyssegaard
