B&O App - Ver. 3.x.x Issues tracker (beta & prod)
V3.3 is available, new issues have been added in the tracker, I didn't find any fix to existing issues I could test.
Cosmetic change: they change the settings cogwheel icon for a person/profile icon which I think is not relevant for global settings. They also introduced a "+" icon in the main page to add products which I think is not appropriate too as adding products is not the action we perform the most frequently with the App. Something like mute sound all or pause all would have had my preference.
Agree with your comments.I would expect to come to my account settings pressing a profile button.On the page you land on instead give you also a possibility to add products, like the “+” does.Not very consistent....V3.3 is available, new issues have been added in the tracker, I didn't find any fix to existing issues I could test. Cosmetic change: they change the settings cogwheel icon for a person/profile icon which I think is not relevant for global settings. They also introduced a "+" icon in the main page to add products which I think is not appropriate too as adding products is not the action we perform the most frequently with the App. Something like mute sound all or pause all would have had my preference. BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
** removed by me **
Version 3.3.2 just out on Testflight.
After a quick check I think only issue #9 is fixed.
Possibly #10 is fixed, but need to test over a longer time I guess.
Tks for testing against the issue list! If B&O could do the same.#9 is not fixed. The point I raised to B&O is that in order to ´shutdown all’ by a 3D Touch action the B&O app must be running in the background previously which makes no sense. Other apps with 3D actions do what they are supposed to do without the need for the relevant app to be running in the background.#10 I also found an improvement since previous version, but as you said, it need a longer observation to confirm.For the rest of the issues, no progress unfortunately. I continue desperately to send feedback with screenshots.Version 3.3.2 just out on Testflight. After a quick check I think only issue #9 is fixed. Possibly #10 is fixed, but need to test over a longer time I guess.
I´m a bit concerned that they only do very limited improvements, like adding new products. Seems not to care about the bigger picture so to speak.
I’m too. For the record, this beta official fix is « Fixed crash in setup after picking color » .....I´m a bit concerned that they only do very limited improvements, like adding new products. Seems not to care about the bigger picture so to speak.
