B&O App on IOS does not detect my S3 speaker
I have not been able to use the App on iPhone and iPod. The speaker connects easily bia blootooth, but the App does not detect the speaker. I have disconnected and reconnected via blootooth several times
Can somebody give some advice?
The Beoplay app? You probably need to update the speaker, using "beoplay software updater" https://www.beoplay.com/support/product-support/beoplay-updater/updater-for-mac
Thank you. Issue solved
