B&O 5500 cd player issue
I just bought a used 5500 system (receiver, cd, turntable, tape deck, remote) and love it ... but, i have an odd problem i'm hoping someone can help with...
When i insert a cd and it starts to play, it makes this high pitched noise for a few minutes and then goes away, i've tried multiple cd's and it still happens. It only seems to happen when i start playing it - if i skip to a track like #5 or #6 it doesn't seem to happen.
I would think if its the din cable it would be continuous noise, but i dont really know
Thanks for your help!!
Bump... just trying again to see if anyone has had a similar issue or has any advice on this issue.
Thanks!
Is the noise coming from the player physically, or from the speakers?
martin
Definitely coming from the unit, i can hear it loud and clear once the cd is inserted and it starts to spin, as long as its spinning it makes this high pitched constant sound.  Thanks so much for your help w/this, i'm really hoping its not a serious issue...
Thanks!
This seems to be the laser focusing,and there is instability in the servo's until the supplies have stabilised?
These fine machines usually benefit from a "re-cap"ie,replacing all the "usually suspect "capacitors where necessary.
Also the deck in this machine is mounted on rubber supports which can collapse with age,making the disc rub on the tray,but this would be present all through the disc I imagine.
Nick
Does anyone have a guide to re-cap a Beogram CD 5500/6500/7000?
When I insert a CD, I can hear the cd is spinning up, but after a few seconds it turns of. I have cleaned the lens.
