B&0 + SONOS vs. Airport Express
To listen music from your PC using AE, you wouldnt need to have airfoil installed.
I have a AE hooked up to my BL6000 and when I wanna listen to music from my Itunes, it gives option what speaker is going to be played to (PC speakers or AE)
There is another Wifi music streamer called Kaiser Baas
You should check it out as well.
You need to have AirFoil if you are not playing music through iTunes, and I have all my music in RDIO :)
I have looked at Kaiser Baas, but I think that this setup is very nice.
It's easy to use and I can now stream all my music so my Beolab 7-2.
