B&O surround system - how to?
Ok, I was wondering how you would set up a B&O Dolby surround system?
It been quite a while since I bought any hi fi so its a re-learning curve. Creating a surround system from scratch is easy with non-B&O components.
Can I run it from say my tv ( a Beovision 8 ) and connect the speakers to the tv and let the tv handle all the 5.1 channel decoding, or do I need to run it from something else ( similar to a normal AV amp )?
Still learning about what does what in the B&O world....thoughts appreciated.
Is your BeoVision 8 a 40"? Which has a surround module so you just plug the B&O speakers in and it works, or a 32". which doesn't have a surround module?
Its a 32 unfortunately.
Do I need to buy a surround module for it then?
There is unfortunately no surround module for BV8-32. Thus you need an external AV processor.
