Scott,
Q. So, hd signal is broadcast to all tv and the control (ir) signal goes over the masterlink. cool. the b&o tv is connected to hd device by a b&o controller. can the hd device be a stb and work through the stb-c ?
A. The device can be any peripheral you would ordinarily connect to a PUC, however, as I mentioned in the previous post (and there could be something I don't understand about STBs in Europe), we don't generally distribute cable/satellite because they're cheap and even in a two person household, people may want to watch different programming in different rooms.
Q. Will this work if, by some miracle, the blu-ray player is integrated in the tv (think bv7) ? do they have a hdmi out option ?
A. Interestingly, no. "If" a Blu-Ray player in integrated into the next BeoVision 7, this solution will not work. Unless they alter their output options (right now it is limited to a single coax), putting the Blu-Ray into the television would preclude it from being distributed.
Q. Does the b&o tv connected to the hd device have to be 'engaged' first or can it be launched from any tv (like with cd).
A. It can be launched from any Bang & Olufsen TV. It works on the same principle as listening to the soundtrack from a video source in an audio only link room. The television can operate while still asleep, which would happen in this case if, for example, you had an AppleTV connected to a BeoSystem 3 in your living room and you hit V.AUX in your bedroom on your BeoVision 8.
Q. As an aside, how do you assign "dvd" to av2. is this some sort of trick with the beo4 ?
A. If you're asking this about a BeoVision 7, you can't. DVD is assigned to the internal drive only. If you're asking this about another BeoSystem 3 based product, I believe you should be able to. I'm not in my shop right now, but I'm fairly certain most of our screens are using AV2 for DVD. I'll re-post if I find something out about this.
