Thanks Simon,
But how can I have access under the plexi glass (inside of the phone)?
Benoît
Thanks Simon,
Benoît
I thought the covers came off pretty easily Benoit on both sides? What part are you having problems with? You should be able to reach the underside without problems.
Simon.
I didn't want to force on the cover to open it but I'll try to do it.
Thank you Simon.
Benoît
I did it!
Well done. Please note that the cover with the plastic (glass) part is expensive to replace if you have any scratches or permanent marks; not worth thinking about in my opinion. B&O dealers were recently giving away the back covers but I think most have run out now although its still worth asking around. If you want any replacement back covers I have several black and dark grey ones in excellent condition. Just send me a PM and they are yours.
Best wishes,
Simon.
Thanks a lot Simon but mine is still fine (and clean now).
Regards
Benoît
I am not good wiyth DIY so i didnt try replacing any panels . B&O Greece did the lot and having all the external parts replaced and a new Ey mains instead of the UK one i had before the phone is as good as new . realy like the BeoCom4 can wait to see the new BeoCom5 though, from another thread it looks awesome :-)
