Can somebody tell me what is a factory setting for backlight on BV7 32" type 9311 and how to increase the backlight? Is 70 correct setting?
BACKLIGHT ON BV7
Hi Peter,
thank you for the answer at the BW forum. My factory setings for BV7 32" type 9311 in the Scaler menu 1 are the same:
brightness 15, colour 23, contrast 50 and scaler contrast 136 as it should be. But I have problems that my TV dimes dark scenes of the films (cable TV) and DVDs very much and the picture gets too dark. This is quite annoying at is happens so quickly (from dark to light and back).
I have contacted Roger who told me that I should try to increase the contrast in the Scaler menu 1 from 50 to 62 but this did not solve the problem. I have also tryed to turn off the film mode but nothing changed. He also told me that the cause could be a defect light sensor. I had my TV for inspection at the B&O service and averything was OK.
Do you have any idea if there were any problems with BV7 32" type 9311 LCD panels? I have calso hecked the menu "Monitor information" and there are two errors listed. Is this normal? As they are listed with numbers and letters I have no idea what this could be. If you have some knowledge about this matter I can communicate the error descriptions.
Thank you for any help in advance.
Vid
Hi Peter
It happens exactly to me with my BV7-32 MK1 type 9311. Can you send me that information too?
have same problem on my beovision 7, was there a fix to this problem ?
What I have used...
Existing Setting 10/07/2007
Scaler Menu 1
Brightness: 17
Colour: 23
Contrast: 42
Scaler Contrast: 136
BV 7-40 Org: Scaler menu 1.
Brightness: 16
Color: 23
contrast: 47
Scaler contrast: 136
(Backlight: 65%)
1st tweak settings:
Brightness: 17
Color: 24
contrast: 55
Newest: (best)
Brightness: 16
Color: 23
contrast: 75
Scaler contrast: 153
Beoaus..
