Avant Video 28 connect to HDR 1
Hi, How do I connect my Avant 28 Video to my HDR1 and use it with a Beo 4 remote ?
When the HDR1 was released it would not work with Avant VCR's. Not sure if this problem has been fixed with a SW upgrade.
Craig🙂
Which type of 28"is it?
The RF could probably work by connecting the HDR to the Vtape connector.
The biggest problem lies in the needed so called "tunerdump". All the channels on the avant has to be dumped in the HDR1.
Manually tuning on the HDR1 will work, but to program the HDR1 you have to use the HDR1 menu. It will not work with record menu in the avant.
The biggest chance do you have if you're having a type 8300 or higher with the most recent software available. With this software is possible to rename all the 3 scarts on the back.
You also have to disable (for a short period) the internal Vtape in the servicemode.
With the older type of the avant is it not possible to attach the HDR1 to the Vtape scart. This is due to the fact that the internal Vtape doesn't communicate through scart but through another internal connector. So the HDR1 will not respond to any instruction.
The only option you have is to attach the HDR1 to the AV scart as a Vtape2 and to programm it through it's own menu. But programming it with the help of teletext will not work. Also the record record function will only work on the internal Vtape.
As Graig mentioned the HDR1 does work perfect with a avant RF (DVD) without a Vtape. Any more recent type of beovision works perfectly.
Does the HDR1 work with an Avant RF with a VCR?
Most likely yes.
Disconect the internal Vtape's scart. Start the avant, then the avant knows/sees nothing on the VTAPE scart.
Connect the HDR1 on the VTAPE scart, it will be recognized as VTAPE and a tunerdump will follow.
Recoonect the internal VTape on the AV scart and name it VTAPE2.
The only disadvantage you will have is that are no videoinputs left which supports RGB. You only have both the camera and the decoder input which only supports videocomposite.
