Avant SW Update Available Now
Carolpa wrote:
fixed in Homemedia:
 88.2 kHz Flac file is supported
i wonder if that also goes for audio over HDMI as discussed in this thread:
/forum/general-discussion-and-questions/sacd-hybrid-reading
The update took almost 20 minutes on my avant and seem to have fixed the problem I had with the light sensor/backlight - but I have to watch it for a few days to be sure.
Not sure but feels like sound and picture are a bit out of sync - but might be me that is tired.
On V1 I noticed update went considerable quicker. It also has DMR now (digital media renderer).
No BeoPlay S8 profiles which I find strange (even if it is BeoLab 14..).
The V1 already had the DMR update!    😁
There is at least one improvement I noticed in Homemedia during audio listening: the cover is no (again!) displayed in high resolution.
Millemissen wrote:
Carolpa wrote:
fixed in Homemedia:
tried an older Oppo. No sound with a Neil Young DVDA in 176.4 kHz. Sound, but distorted, when playing SACD. Note: input Mch SACD - BV11 displays Input  PCM 2ch.
@carolpa: I sat the OPPO to do all the decoding and send the processed sound as (multi channel) PCM to the BeoVision. Works great.
Roger
Correct Roger!
But BV11 doesn't play 88.2 or 176,4 kHz resolution through hdmi.
When I use the Oppo BRP103 I have sound because the Oppo resamples the signals to 24bit 48 kHz. If I feed the BV11 the same format with an Oppo DV981HD or Oppo BDP83 I get the situation as discribed.
Before the BV11 I had a BS3/BV4 combi. All LPCM formats were reproduced when processed by the Bluray player.
The hikup on netradio is still there, very anoying
What hickups? Do you use the wifi connection? I found that it works very badly and switched to ethernet which works much better. Haven't had problems with radio hickups in the old firmware - but some stations would not work all the time.
I use ethernet to but i have hikups every few minutes. I'm not the only one in the Netherlands. I have no trouble on my Denon receiver but with the Avant it's anoying.
