Avant speaker grill removal
Anyone have a diagram or instructions?
I need to replace the drivers.
Jered
Push or slide the grill either left or right (can not remember which but you will notice if you try) about 5-10 mm and then pull out.
Slide it to the left and then pull - do it gently though - it sounds worst than it is!
