As mine in now dirty grey instead of "clean" grey - I'd like to remove and clean it. How do I remove the cover from the chassis?
I reckon I can clean it with soapy water and use a hairdryer to dry it - but any help would be appreciated.
Hi there...my first post!
I once had the speaker frets on my Century dry cleaned....they came up like new! Local dry cleaners charges me £5...bargain!
I'd like to know though how to get the cover off the Avant if anyone can help me with that.
You CANNOT take the cover off of the plastic holder as you can see from the picture below because it is bonded into the plastic on the four corners and along the edge seam.
i just hoover mine VERY carefully , seems to do the trick
just don't use the metal edge of the hoover end , use a plastic one or you might tear the cloth !!
-deleted-
