Avant new software update available
Hi
I am doing an update to the Avant. It says latest software 14 September.
Just a friendly reminder to update if you so wish
It says it takes 10 mins once it's downloaded and I attest to it taking that long to install.
No notes about the update
There's an update for the BV11 as well. No notes for that update neither. I haven't noticed anything new since the update.
Neither have I
I was thinking if it was for the a6
I just got the "14-09-2015" update as well (automatic) on my BV11.
My BV updated Sunday overnight, found out on Monday when I turned the TV on. As with the others in this thread, no update notes.
My BV11 has updated too. If set to automatically update all you can do is accept it via the Beo4 when the update screen shows on turning on the TV.
Nothing to worry about..... unlike the IOS 9 for the iPad which arrived this morning and I am dithering over as the last update certainly slowed my iPad down considerably.
Graham
Graham
And mine too
I reckon it's a planned obsolescence in order for you to upgrade.
Graham
I don't know why this happens, but give it a little time. It should eventually smooth out and be back pretty damn near close to the speed it was before. The same happened with my 6 Plus when I updated to iOS 9 but over the past couple of days it has begun to get back to normal. Same thing also happened with the retina Macbook Pro when I updated to Yosemite... I was quite disappointed... but eventually it got back to normal.
I updated my iPad air2 last week and I've seen no slowing down. Just some nice new features.
Dave.
