Avant for bedroom
Hello all I am thinking of buying an avant for my bedroom tv with a sky box connected to it (locally) Did all of the avant's have master link and stb control for a basic sky box for free view? I think a basic one with master link should be ok as long as i control a sky box! Did the avant use an ir blaster like the new tv's do. Have an ir blaster like the new tv's do? Do they all have master link and can be set to video option 6 so I can access vmem audio from it?
I have a US Avant in my bedroom and like it. However, I would certainly not buy an Avant in this day and age. The Avants were plagued with a fault in their component hi-def input that often caused a magenta hue in the video. Furthermore, the "high def" is only 480p. The lack of an HDMI port today would be a deal-breaker as well. The lack of an HDMI port and lack of 720p would prevent the use of the new second generation Apple TV. The Avant was fine in a world where high definition was still in its infancy; however, today it is just too far behind in technology.
What is the alternative that is cheap! I will only use it for a sky box and to access my apple tv sound from the main room Beovision3 maybe I already have the stand
Sean,
Go for a late model dvd RF28 or 32.
I would avoid a curved screen avant nowadays - apart from potential faults and age, they just look a but "old" with a curved front.
To answer your points for UK variants - using a sky box into the RGB scart imput is a superb picture.  Full control via STB-PUC codes and a blaster ...just like your BV7.
I use the VTAPE input for line-level sound from a pc, running spotify etc.  So, in link rooms, its just Vtape for digital sound.
We have two avant's - one with sky HD (used as a standard sky plus box, I don't have sky hd subscription, but bbc hd, and a few others are still available and it is a stunning picture), and one with bt vision.  The picture really is also superb.
A bit small compared to many peoples TV - and if your used to a 40" LCD, it will look tiny.
One last point - the sound is also great..... its a big box, so loads of air to move, and avants just sound "right" to my ears - like BL4000, a very natural balance is achieved.
just check the tube is OK before you buy.....£££'s to replace, far more than buying the whole thing in fact.
Yeah see if you can find a beovision 3, post 2004
Get an RF Avant. Great picture and great sound for a bargainous price.
US Avants were different from RoW don't forget.
I'm thinking about getting another...
I would find the BeoVision 8 price to be quite reasonable for a much more technologically up to date tv for the extra cost.
Seanie..
i have an RF28 in my bedroom, with local sky box, also connected via ML to my Ouverture....but...also....connected via RF to my BV7 downstairs and the MiniMac...so in my bedroom i can have...
Local Sky
Downstairs SKY+
Ouverture (radio/cd)
Itunes from the Mac(air ported to the ouveture)
its a bit fiddly to remember how to watch a recorded programme from the downstairs box, but its only because i dont do it very oftten !
hope this helps...and Avants are chip and chips these days....
Andym
Excellent i think i will find a Avant or a BV3 for my new bedroom.
So am i correct in thinking that both TV's has STB and Masterlink as standard?
I spoke to the dealer this morning and he said that if i set it to option 6 then i should be able to access the sound only from vmem connected to my main tv by using vmem or av-vmem.
I year what you are saying but the Beovision 8 will be around 5 times the price of an excellent late-model  Avant which is now at a price where you won't be too bothered if it expires after a couple of years. this is a bedroom TV not a front room TV after all.
Personally for a bedroom I would go for the latest LX I could find,  cost would be virtually zero but it is more compact than the Avant an still a great TV
Simon
