Avant DVD
I have 2 problems:
1. The "Timer Play" option from the menu has disappeared.
2. The TV will shut down by itself after a few minutes (even the red dot disappear and will reappear after a minute or two)
I hope problem 2 isn't a big problem that will lead me to replacing the TV!
Most Bang & Olufsen TV's will shut themselves down after a while if the have a fault. They do this to ensure no further damage is caused to the television. I would recommend getting your dealer to look at i for you.
