Is it possible to remove the contrast screen on a curved screen Avant? Mine's a bit grubby and I would like to give it a clean. Is it just brute force on the plastic sorround and I am being too careful.
Don't use brute force removing the plastic surround: there are two (large plastic) screws standing in your way. You will find them if you look below/under the screen and surround, just where the red on/off switch is hidden...
Its a 28".
Basically I presume you can remove the black plastic trim from around the screen. I have so far been unable to do this. Is it possible and does the glass screen come off after that.
Sorry to bring this old thread up again..
I have a curved screen 28" vcr model here and it has spent its life in the living room of a heavy smoker. So it's in desperate need of a good clean of the glass screen in front of the tube.
There is no service manual on site and I'm not a fan of trial and error:)
Could somebody let me know please how to remove that plastic trim?
