Avant + BeoPort + CX50
Hi, im new in the world of B&O, and recently received a pair of beovox CX 50 with a MCL-2A(right?) and an eye, from my parents since they don't use them any more.
I have in the mean time fallen in love with the Avant 32" VHS and im thinking about connecting it to a BeoPort.
The question is then whether it would be possible to place my CX 50 in the kitchen and connect them through the Avant so i can listen to N.Radio from the beoplayer on my PC?
 Thanks.
Jesper (:
You will need a ML/MCL to drive the CXs. But I don't know if it is possible to have the BeoPort as Audiomaster with an Avant.
πŸ™‚
That got me one step closer.
thx (:
Come on guys... πŸ™‚
I know we had a tread about using the BeoPort as audiomaster, but I cannot find it, and I cannot remember if it was possible with an Avant.
Jesper is a friend of mine, and I know he would appreciate the help... πŸ™‚
Christian
I am fairly sure that the Avant cannot play NRADIO or NMUSIC, however you can watch TV, SAT, DVD,VCR on your PC via Beoport.
This is the conclusion that the PCG gives with just an Avant 32 VCR and a Beoport with TV card.
Wish I could be more helpful,
Andy T.
************************* VIDEO SYSTEM SETUP **************************
BeoVision Avant 32" 100 Hz MKIII (842x) SW 3.x
Connection Video
Connect the aerial to the aerial input of the TV-set.
Selecting option on the TV-set
Option: OPTION 1 (Factory setting), with Beo4
                Press:                          | Display:
                STANDBY + LIST at the same time | OPTION?
                GO                              | V.OPT
                1                               | Observe confirmation
                                                | from BeoVision
Note!
If the TV is equipped with a Dolby Surround Module, the TV's default
SPEAKER mode will be 3. This has the effect that the speakers of the Avant
will not play stereo.
To avert this, the TV Front Speaker Setup must be set to 'None'.
This is effected via the menus Setup -> Sound -> Speaker.
However, this is not possible on Avant 50Hz with S/W lower than 2.0
In case of interference between the modulator frequency and other
signals in the UHF region, adjust the modulator frequency
from the TV menu. Procedure:
         Setup / Tuning / Link Frequency
When you have found the desired frequency, press (GO/PLAY) to save it.
The recommended distance between stations in the UHF region is 16 Mhz.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo4
The following remote controls may also be used:
Beo5
Setup for Beo4 remote control:
Beo4's "LIST" must contain the following items in order to be able
to operate the Main Room products.
FORMAT STAND CLOCK
LARGE REVEAL INDEX UDDATE MIX SUBCODE STORE
AV      (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
*************************** LINK SYSTEM SETUP *************************
Master Link
BeoLink PC 2 / BeoPort
PC TV-card
Connection
The aerial signal is distributed to the PC TV-card in the Link room from
the aerial output RF OUT on the BeoVision in the Main room.
Connect the Master Link cable to the Master Link socket of the Video
Master in the central room.
Connect the audio cable between AUDIO IN on the BeoLink PC 2 / BeoPort box and
the socket on the PC sound card marked LF OUT/LINE OUT/OUTPUT.
Connect the USB cable from the BeoLink PC 2 / BeoPort box to a free USB port on
the PC.
It is
important
 to install the USB driver for BeoLink PC 2 / BeoPort on the
PC before connecting the USB cable to the PC
Setting of option in the Link room
BeoLink PC 2 / BeoPort:
  Option 6, via the PC
Start BeoLink PC 2 Configuration from the BeoPlayer toolbar on the PC.
Select the "Advanced" tab.
Select option 6 in the "BeoLink Option" section
Note!
The audio master in the main room cannot distribute PC sources, e.g.
N.MUSIC and N.RADIO to the Master Link system.
The PC sources are therefore only local sources in this Link room
IR receiver for BeoLink PC 2 / BeoPort. Order no. 8087030.
BeoLink PC 2 / BeoPort only works when the PC is turned on.
********************* REMOTE CONTROL FOR LINK ROOM ********************
Beolink 1000
Beo5
Setup for Beo4 remote controle:
Beo4's "LIST" must contain the following items to be able
to operate the products from the Link Room.
MONO (changed to SOUND with S/W 4.0 or higher in Beo4)
(RESET)
LINK
PC      (only with S/W 3.4 or higher in Beo4)
N.MUSIC (only if Beo4 has S/W 4.4 or later, otherwise use A.TAPE2)
A.SETUP (only with S/W 2.0 or higher in Beo4)
from/to the List
But if he disconnect the Avant, I think it would be possible to choose N.MUSIC in the kitchen via a ML/MCL converter.
Will he loose this possibility, if the Avant is connected?
I really don't know ChristianπŸ€”
Trial and error might be best, unless someone with experience can comment.
Yeah, that might be the solution. I have a BeoPort he can borrow, if/when he buys an Avant.
Thanks for giving it a thought. πŸ™‚
Hi guys, yes, you can use your BeoPort as an audio master and connect it to your Avant, that's what I was doing until I bought a BV3 (and connected it the same way).
Your Avant should be in V OPTION 2, and your BeoPort in option 0 or 2.
You should have no audio master connected to the system.
Enjoy!
Cool - thanks guys!
I'm looking forward to getting my hands on the avant (:
