Hi all,
I have had a good search around the forum and could not find the answer I was after, so I apologise if I'm covering old ground but I just couldn't find it.
Anyways, I have my late Avant 32 DVD (with Surround module) hooked up to my BC9500 via a Beolink converter 1611 (both audio aux and fully wired powerlink are connected between the 9500 and converter) trying to play through a pair of Beolab 5000's. The speakers are hooked up to the Avant and work fine through the front speaker outputs. The Avant is set to 'option 2' and the 9500 'option 0'.
The problem comes when trying to play any 9500 source through the Avant. All appears to be well initially, the displays on the Avant show the source, the 9500 powers up and the source begins to play, the speakers power up and the displays show the source, volume etc but there is no sound output from either the Avant internal speaker or the 5000's. Connected separately both units play through their outputs without fault.
I have been through the setup numerous times and have powered the unit of then on again several times too. Am I missing something within the setup or could there be a converter fault?
Any help would be greatly appreciated!
Best regards
Gregg
