I will hold my judgment of the panel until I have tested today's SW release for the Avant, which is claimed to be the same as the one used by flatpanels.dk in their review.
Floor stand changes position all the time? How did you set it up?
Roger
The panel won't change with a software update of the TV itself. The panel is very much fixed. As a pair of connected speakers. It just displays whatever is inputed to it.
I mean, for example if I move the stand to my current place in my sofa and then change source to TV from Apple TV that it might move to the default TV position. (Not sure it does this) BUT when I change to a music source, then it always goes to the audio stand position and it is very annoying because they are very different and it takes time. When the TV is on I dont want it to move around (same with speakers). A possiblity to change that behavior would be awesome.
Did the software come out today? Im at work so I haven't been able to try it out yet. My biggest issue with my Avant is that it dims and brightens the screen very strangely in dim room light situations. I have a new one waiting to replace my current Avant - perhaps it is a hardware issue but I think not..
When I change video sources, the tv does not change position unless of course you have assigned a change of position with the My Buttons. The only time the tv moves without me choosing is when moving from a video to an audio source. Now it obviously moves into audio position. A way to prevent this is to use a My Button shortcut for your audio source - set it up to use the same stand position as your video source. This should prevent the stand from moving.
I'm also not experiencing the popping you mentioned when changing source. The only popping I experience is through my external speakers when they're turning on or off - which only happens when I turn the tv on and off (with power saving on). With power saving off, the speakers stay on all the time so no popping at all. But I felt that was a waste of electricity having the speakers on all the time, so I turned power saving back on.
