Avant 55 and Sky Q
I have the 2TB box, Sky support say the box is detecting that the TV is not compatible. Clearly others have it working which is frustrating!
I have tried other HDMI cables, SkyQ is plugged in to HDMI port one, no difference...
If the actual Sky Q box isn't giving you the option of choosing 2160 then I would run an update on the Sky Q box as there was recentish software update which included the 2160/ UHD functionality, without this you won't have the option to select 2160.
Thanks, I have tried this and no luck... Sky are sending an engineer out so I will have to wait. Very frustrating!
