Avant 55 and Sky Q
Hello All
I ordered SKYQ this week now its available without SKY Broadband.
Cannot wait, 23 days to go.
Going to have a main box on my BV7-55 and a Mini box on my V1 in my Bedroom.
Also means i can loose my HDMI Splitter and Apple TV Box.
still charging for the equipment and still no 4k channel
I think i will wait
Hello there
i am so excited I cannot wait.
not really much choice in Milton Keynes as no Virgini media available here. Only choice is sky or BT I think. Cannot wait for a shared planner
Hi there,
To all of you who have an Avant and Sky Q, I was wondering whether you had tried the newly released 2160P mode that came with the August software update for Sky Q. For the life of me, I seem entirely unable to make it work. It synchs perfectly in 1080p mode, but comes up with an error in UHD mode. Just tried a new HDMI cable and no joy.
Any ideas? Appreciate it!
Hi mawheele,
I don't have SkyQ myself to try this, but I have heard that if you go to the UHD resolution selection screen where it goes black and fails - if you were to click 'ok' to this resolution - even though you can't actually see it - then it will succeed and work on the Avant. Maybe try it with 1080p so you can see how to click on ok, then try it blind on UHD?
Hi - thanks for the trick. As you say, quickly moving left  and pressing enter while the screen was blank worked the trick. Not a great experience, but delivered the right result. Thanks again.
I've tried this several times and I can not get my TV to accept the 8 bit setting. I've selected left & ok on the 10 bit settle no, but my Sky box freezes. When I try 8 bit, selecting left & ok does nothing at all. Very frustrating. Having spent so much on my TV I am really not happy that I can't watch any of my Sky content in 4k
Good tip, thanks! Took a few attempts but got there eventually, the Sky Tech had no joy neither did my B&O man who was over at the same time but perseverance paid off in the end thankfully. Also had to select Dolby Digital on the sound as default seems to be just stereo.
I agree, this is definately something to be looked at by way of a new Beosystem 4 firmware update. Whilst it works perfectly, its not a great experience.
I have an Avant 55 with Sky Q silver but do not seem to have an option for 2160p... Has anyone experienced this? I have tried updating the software but no luck...
