Hi!
I've just bought pre-owned Beovision AV9000 complete with MPAV9000, but I can't understand several things:
1) Why I can't set up audio preferences to "Stereo+Center" mode forever? I have to change the sound mode manually (SOUND -> 3) every time when I turn on RADIO, CD or A.TAPE, while central speaker is switched on automatically for TV, SAT or V.TAPE!
2) Why it doesn't indicate the volume level on displays of TV and audio system during adjustment? Is it possible to change mode, isn't it?
3) What a button on the TV, that's located on the left hand of power button (forehand, below of tube)?
4) Is it really have no timer?
Thanks in advance!
AV9000 + MPAV9000 troubles
@1: For all audio sources like "CD" , ... speaker 2 = stereo is the default setting
while for all video sources like "TV", "SAT", ... speaker 3 = dolby 3 = two front + center
is the default setting. Unfortunately these default settings can only manually be
overruled each time by pressing SOUND and then 1/2/3/4or5
@2: As far as I remember - no
@3: Play-Timer on/off for an already programmed timer (see @4)
@4: You'll need a 2-way remote like the BeoLink 5000 or 7000 to program a timer for audio sources.
Dear Vienna, thank You very much for detailed answer!
- Well, is it true for more new TV sets, for example BeoVision 7 or 9?
- I'm sure that displays of Penta MK3 indicated the volume level during adjustment. Display of Penta only duplicate one of displays of TV set, doesn't it?
- Only for audio sources? What else opportunities will appear with these remotes?
Thanks in advance!
Hi Guys,
Regarding #2: The volume level shows on my BL5000/3000 ( and I suppose on Pentas also), but not visible anywere on the AV9000.
/Peter
True, you can set the start (default) configuration for the speakers on newer TV-Sets.
Other B&O TVs of the last 20 years (e.g MX series) don't display volume changes on
the screen = "inside the picture".
If they have a separate display "outside" the screen (e.g. Avant models) these data are
displayed.
If you connect speakers with a display (e.g. Pentas) you'll get these informations displayed.
- Only for audio sources? What else opportunities will appear with these remotes? **)
Using a one way remote like Beo 4/5/6*) or BeoLink 1000 you can only access the timer programming for
the VCR using the on screen menu.
Both 2-WAY REMOTES = BeoLink 5000 and 7000 are able to program ALL TIMERS
(record timers as well as play (start) timers and standby (shut down) timers for ALL SOURCES.
*) you need IR 2-way for the AV 9000 - the 2 way capabilities of a Beo6 are wireless.
**) Data about volume, sound, station #, track #, ... will be displayed on the remote
Peter, tks!
Vienna, many thanks!
Both (BeoLink 5000 and 7000)?
Peter, tks!
**) Data about volume, sound, station #, track #, ... will be displayed on the remoteBoth (BeoLink 5000 and 7000)?
Both!
PS.: Consider an upgrade of your membership to silver or gold level.
Beeing owner of vintage products this will give you access to the
archive of user and service manuals for B&O products ...
